A question I get asked the most is, “What products do you use for pain relief?” so today I wanted to talk about that.
Here is a list I have compiled of several products that you can use to help with your pain.
*Products are ones I use or have personally been recommended to me via advice or questionnaire*
-prices will vary-
(Any item with ** next to it is one I personally use/have used)
About this Product (from website)
MENSTRUAL CRAMP RELIEF - The EM50 effectively relieves menstrual and endometriosis pain using transcutaneous electrical nerve stimulation (TENS).
TENS WITH HEAT - Our EMS Muscle Stimulator features a heat function for targeted relief of cramping and 15 intensity levels so you'll be sure to find your preferred setting - with auto shut-off after 20 minutes
WHAT'S INCLUDED - 1 x Menstrual TENS Unit EM50, 2 x self-adhesive gel pads, 1 x USB-C cable, 1 x Instruction manual - the device comes with a limited lifetime warranty
GEL PADS: 2 Self-Adhesive TENS Electrode Gel Pads are included. Replacement gels are available for purchase.
Product Dimensions: 3.1 x 7.5 x 0.2 inches; 0.5 Pounds
Order Here:
Ovira's period cramp relief device sends small electrical pulses through two Love Handle pads which stick on your stomach or back. The pulses overload your nerves, stopping the pain signals travelling to your brain.
No signals = no pain.
Order Here:
Symptoms are often more than skin-deep, and traditional topicals may not be enough. For full-body relief, cannabinoids need to penetrate beneath the top layer of skin and reach the blood vessels. That’s why Doctor Solomon’s proprietary transdermal carrier uniquely delivers cannabinoids to work beyond the surface for potent and systemic relief.
Product cannot be purchased online
Dr Teal’s Pure Epsom Salt products can help rejuvenate the body, quiet the mind, and increase vitality. Our products combine the ancient benefits of pure Epsom salt with the revitalizing and restorative qualities of natural essential oils.
Order Here:
With our Relief Pad, soothe your cramps and muscle tension naturally.
The Relief Pad utilizes heat and massage therapy while being portable and lightweight to take with you wherever you go.
Discreet enough to be worn on the tummy or lower back for on-the-go relief.
Order Here:
